RE: Avistar ARF Build
On the Avistar's angled wing tip, there is a hole in the flat part of the tip. You can cut the covering away there and put the weight needed in through that hole, then simply cover the hole with tape now. Behind the angled tip there is a rib readily accessible to glue the weight to. Then later a small piece of white self stick trim and you're good as new.
Duke
