RCU Forums - View Single Post - First Flaps with Comp. Radio
Old 05-23-2002 | 02:54 AM
ysrcflyer's Avatar
ysrcflyer
Default First Flaps with Comp. Radio
The only time you would get elevator to flap mixing is when you turn on the elev-flap mixing switch.(upper right side of radio)
You can pull really tight & sharp loops & corners with this.
the flaps to elevator mix (6-2) will come into play when you rotate the flap knob.
I don't know the specific bhp of the YS 61. It is no longer avaliable.
This used to be the engine of choice for the pattern crowd untill the 4-stroker's became the norm.
I originally had a ASP 61 in the chippy and had nothing but problems with consistent runs-lots of dead sticks after hammerheads. I even tried a perry pump to no avail. After bolting on the YS I could not believe the HUGE difference in power and it turned the plane into a real aerobatic performer.
