RE: Engine Mounting
A dead center tool is expensive and is not mandatory. Often I use a drill the correct size of the engine holes. Hit the drill with a small hammer and rotate it 90 degrees and tap it again and the center of the hole will be marked. Sometimes I will mount the engine with a single screw and then mark the other three holes.
Bill S
