John, you should not have to replace the parts. Hopefully you realized your mistake before you also glued on the rudder. Perhaps even before gluing the horizontal stab to the fuse? Just cut through the CA hinges. To re-hing the elevators just cut new slots in different locations. Use new CA hinges, or your hinge of choice. And don't forget to connect the elevators this time.
