RCU Forums - View Single Post - Genesis starting problems
Old 02-03-2005 | 06:14 PM
BILKO1
Default RE: Genesis starting problems
If i put my finger over the exhaust outlet the fuel does not flow in the fuel line unless i open the throttle a bit. I do not have the throttle set to shut the engine down as once started the motor idles fine. Should i clean the one way bearing out with thinners or should there be a small amount of lubrication left?
