RE: Any interference installing throttle servo by zenoah g26?
Make sure you use a nylon semi flex rod instead of metal on the throttle servo. Actually the farther away your servo will be the less chance you will have of interference. I installed a G26 on a Super Stearman by GP and did just that. And finnaly got it to go good. Hope this helps.
