RE: Extra 2X2
Well that’s Brilliant !!! Un solder, adjust and re solder the header. Maybe CA should put that step in the Manual. Or at the very least tell their employees about so when you call they at least have that suggestion. Well to be fare, this is the first run of this product, but still, CA says this is the setup they fly.
1 question. With the Pipe being a 180 and a 90 deg parts, adjusting the 1 connection would put the exit end of the header at an angle wouldn’t it ? Although it appears that may work, to get the can back level again, doesn’t there have to be some bend in the Teflon tube ? I am told that can be a problem. If we had a header with an actual drop in it (rather then just angled down) that might work even better. Or one that was a 3 piece unit, then we could customize the fit, get the correct amount of drop and have the exit level, not at any angle.
But still, your solution is better then what I have now and the best suggestion I have heard yet.
So who’s bird is that in the Pics ? Who came up with the idea ?
In all my calling and countless E Mails to CA tech support (you can’t get CA on the phone, only your sales rep) Tech support has never returned an E Mail. Only my sales rep, and he had no real suggestions. Just denied there was a problem. Acted as if this was the first time anyone had this problem.
I love CA’s birds, but I am sure frustrated with the service (tech support).
DA on the other hand has tried very hard to help. Good people over there at DA.
