RCU Forums - View Single Post - ROD HELP
Thread: ROD HELP
Old 02-04-2005 | 09:22 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: ROD HELP
You should have two thin plastic tubes. One rod goes into one end of each tube. The tubes are treaded through the larger tubes that are already inside the fuse, and attached to the servos. The inner tubes are then cut to length and rods inserted into the other end for connection to the control surface
