RCU Forums - View Single Post - ROD HELP
Thread: ROD HELP
Old 02-04-2005 | 01:14 PM
bobmac
Default RE: ROD HELP
ORIGINAL: MinnFlyer
You should have two thin plastic tubes. One rod goes into one end of each tube. The tubes are treaded through the larger tubes that are already inside the fuse, and attached to the servos. The inner tubes are then cut to length and rods inserted into the other end for connection to the control surface
Yes, this is the correct way. Turn to page 51 in the instruction book. Step 193 is where it begins talking about it. Don't forget to cut the rods from 10" to 7" before you install them into the nylon pushrod tubing. If you are building the ARF version, the page and step numbers may be different. You are almost there! Bob
