RCU Forums - View Single Post - E-Flight Tribute
Old 02-04-2005 | 11:50 PM
Tall Paul
Default RE: E-Flight Tribute
My first flight with my Tribute after the first (and last) flight with the kit motor, using an E-Flite 540 kv bru$hle$$, Phoenix 10 ESC, and 2x1500 lipos was in a wind when no one else would fly.. not a problem.
It can't do anything other than fly around with the kit stuff, but with the bru$hle$$ it's a winner... capable of doing more than I can.
The landing gear is awful, needs bracing, the wing bends amusingly/alarmingly without bracing.
With the Phoenix ESCs, you MUST program the low voltage cutoff to suit the number of cells you're using.. 6.0v for 2 cells, 9.0 v for three.. otherwise the battery will dump totally in flight, which is a drag..
Wire bracing the landing gear and adding CF rods to the bottom of the wing and fishline to the top of the wing stops the flexing..
ID:	225102   Click image for larger version
ID:	225103   Click image for larger version
ID:	225104   Click image for larger version
