RCU Forums - View Single Post - Any interference installing throttle servo by zenoah g26?
Old 02-05-2005 | 07:40 AM
BillS
Default RE: Any interference installing throttle servo by zenoah g26?
If interference does occur, what methods can be used to prevent interference?
How do you anticipate knowing when a glitch occurs? If it happened to be a big glitch how will you determine from the many thousand pieces carried home which part failed?
Others have suggested mounting all radio gear far away from the engine. I have mounted the radio gear at least two feet away from the engine no matter how much trouble the throttle linkage is to work out. For me it simply is not worth taking a chance. After the crash it is almost impossible to determine the cause.
Bill S
