Venture Problems???
I have a Venture and had two problems so far.
1) The biggest problem so far has been the plastic motor mount. The nuts (2 out of the 4) that drop into the motor mount slots are turning when I tighten the bolts that hold the mount to the frame. It is VERY frustrating and I can't figure out how to properly secure the mount to the frame.
2) My engine shaft nut has vibrated loose 2 times on me. I did use locktight on it.
I am a newbie and was just curious if anyone else has had thes problems.
Otherwise it has flown GREAT! I'm starting to ease into forward flight after 22 flights over the past two weeks.
Shawn Kappner
