RCU Forums - View Single Post - Venture Problems???
Old 09-08-2002 | 11:18 PM
Woody218's Avatar
Woody218
My Feedback: (24)
Default Venture Problems???
1. Get an aluminium motor mount for an Ergo 30, it bolts right in.
2. What are you using to lock the crankshaft while you tighten the crankshaft nut? A good way to do so is to remove the engine's backplate, and stick a plastic toothbrush handle in between the crankshaft throw and the crankcase while you tighten the nut down.
