RE: hummingbird control....
Make sure your getting a full charge when your charging up your battery. The lower the charge in your battery, the less control on the tail your going to have. I find with mine, when my battery has a full charge the tail holds good, but as the battery starts to run down the tail won't hold as good.
If your using the wall charger, you should get yourself a good peak charger, those wall chargers aren't much good.
