RCU Forums - View Single Post - Carl Goldberg Tiger 60 Kit problem
Old 02-06-2005 | 10:45 AM
dshepard
Default Carl Goldberg Tiger 60 Kit problem
I am building a CG Tiger 60 and have run into a problem with the wing. The kit is supplied with factory made notched trailing edges. The problem is they are too short. Both the Leading and Trailing edge need to be 33 1/4 inches long (each wing). The supplied trailing edge is only 32 1/4 inches long. The supplied Leading edges are 37 inches long which requires trimming which is understandable.
Has anyone else built one of these kits before and if so did they have this problem? I plan on contacting CG tomorrow to see if I can get the correct pieces as they would be difficult to hand make.
Derek
Concord, NC
