RCU Forums - View Single Post - Crashed Wankel 30: HELP!!!
Old 02-08-2005 | 03:45 AM
Rupurt's Avatar
Rupurt
Default RE: Crashed Wankel 30: HELP!!!
Maybe you could bore out the casting and tap a thread, then make up a threaded insert. TIG welding will most probably get the casting to hot and if the weld area isn't 100% oil free you will end up with a porous weak weld.
good luck with whatever you end up doing.
