RE: How do I setup elevator compensation on Optic 6 with a V-tail Sailplane
To get the v-tail to move in the proper direction when you first set up the plane, did you reverse the travel % or did you reverse the channel? If you reversed the travel % this is probably causing your problem. You have to reverse the channel and not the % under the vtail mix.
