Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
How do I setup elevator compensation on Optic 6 with a V-tail Sailplane
Old 01-24-2005 | 08:24 PM
ultra6a's Avatar
My Feedback: (27)
Default How do I setup elevator compensation on Optic 6 with a V-tail Sailplane
I have an Adriana Sailplane that I am attempting to setup up elevator compensaiton when crow is activated on my Optic 6. I have not been able to get both v-tail control surfaces to operate in the same direction. When I activate crow the surfaces respond as rudders and not elevators.
Old 01-25-2005 | 12:43 PM
Brendan Lugo's Avatar
Default RE: How do I setup elevator compensation on Optic 6 with a V-tail Sailplane
Outside of the !QUOT!crow!QUOT! function does the V-tail operate correctly?
If the v-tail functions properly outside of the crow function you should only need to put a % in for channel 2 to have the proper compensation when the crow is activated.
Old 02-07-2005 | 09:50 PM
ultra6a's Avatar
My Feedback: (27)
Tried that. The vtail control surfaces still work in opposite directions and not together.
Has anyone else run into this problem? If so what was the solution?
Old 02-08-2005 | 11:48 AM
To get the v-tail to move in the proper direction when you first set up the plane, did you reverse the travel % or did you reverse the channel? If you reversed the travel % this is probably causing your problem. You have to reverse the channel and not the % under the vtail mix.
