RE: Velocity stack required for this?
Deadeye
The main problem is that the air flow will be much different in the air than on the ground. Get the engine to run as well as possible on the ground and try flying after. Plan your testflight well, think of each eventuality and what you will do. If needed, get an experienced pilot to either call for you or to do the testflight for you.
Safe flying!
