ST 3250 problem
I was just told by a very ST knowledgeable engine guy that ALL 3250 engines have a problem with the piston ring not having sufficient end gap thus causing overheating, flameout and deadsticks. Fix is to remove ring and grind off about .040
Can you comment on this before I put my new P51 in the air.
Regards, Dick L.
