RCU Forums - View Single Post - 3D Hell Raiser
Old 02-09-2005 | 12:31 AM
  #105
vypr
Default RE: 3D Hell Raiser
ORIGINAL: TManiaci
h. Everywhere you say "glue it", but you don't make it clear with which glue. We found the foam-safe CA that came in the kit would take hours to set in some cases. We reverted to using 5-minute epoxy everywhere, which seems to make a really super bond and beefy jounts.
One little note on foam safe CA. I tried it once and had the same results. Dry time was insanely long. I gave up and used epoxy.
After a suggestion from a buddy, I used some CA accellerator for the first time in years. I'm not going back to epoxy unless I have to! Joints harden up instantly. Much better way for a light airframe than epoxy.
