RE: AMT ECU software up grade
Buck, I open the transmitter it would be a headache to convert switches. So I will leave it on Ch8 or aux3, but you must set your failsafe to go to middle position not low. If you go low your ECU will shut off instantly, AMT reprogram the normal shut down time to 2sec instead of 6sec. Check it out you should see what I'm talking about.
