ORIGINAL: EddieWeeks
There is nothing wrong
with a plane going crazy in the air because at least you know its the radio and you can still
kill the engine because it only takes a few good frames getting through..
The idea that at least one valid frame will get through seems like a very bad assumption. Depending on the nature of the interference source you
may get patchy interference (in which case you get lucky) or you may get totally swamped (as I was when I got shot down many years ago by an illegal CB setup that was blasting out enormous amounts of energy on my channel - no chance of my teeny little TX signal getting through all of that).
