RCU Forums - View Single Post - CG Problem !!!!!! HELP NEEDED :(
Old 02-09-2005 | 06:49 PM
DragonHeart
Default RE: CG Problem !!!!!! HELP NEEDED :(
Hi,
The P-40 calls for a 70FS but ive gone for a bit larger with an 80FS soo thats why i may be having these problems.........
I will try to balance with my fingers tommorow like someone suggested......... but if its still alot out i will try to move the batt pack one step back and then cut some balsa away in the tail then glue wieght in............
Will it stay secure if i add weight that way ? will i need to reinforce the block im gluing the weight 2 ? i guess expoxy should hold it in place ok....
Thx for ur help just never had a tail heavy problem like this, as its allways been nose heavy....
