RE: CG Problem !!!!!!
Well, I suppose you could balance a low wing plane on the CG machine right side up also. However, the CG of the fuse is above the pivot point, so one little delta would pull the nose or the tail down. This is similar to an inverted pendulum or trying to balance a stick vertically on your finger.
