RE: BladeRunner - Rotation Problem
Yes, slightly changing the weight will change the trim point on where your rotation stops.
I noticed this effect when doing things like removing the plastic jacket or mounting a heavier cell. You only need to add a small piece of foam or rubber tape underneith the chassis to make this change.
Good luck!
