Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
BladeRunner - Rotation Problem
Old 02-11-2005 | 01:35 PM
Default BladeRunner - Rotation Problem
I just got a BladeRunner and I can't seem to stop it from slowly rotating while flying. The trim control slows the rotation but it doesn't stop it entirely. I can stop the rotation by using the left/right controls but then it's hard to move it forward or backward. Is there any way to stop the rotation? Thanks in advance.
Old 02-11-2005 | 04:35 PM
Greg Covey's Avatar
Default RE: BladeRunner - Rotation Problem
Yes, slightly changing the weight will change the trim point on where your rotation stops.
I noticed this effect when doing things like removing the plastic jacket or mounting a heavier cell. You only need to add a small piece of foam or rubber tape underneith the chassis to make this change.
Good luck!
Old 02-11-2005 | 05:09 PM
[sm=bananahead.gif] yes i noticed this with mine to
