Hyde Mount
Go with the Hyde mount...It truly is the best soft mount on the market.......NO maintenance and it will outlast your airplane.....Not only that but simple to install and we have been using them in pattern planes now for almost 10yrs....I have never heard of a failure and I can tell you this once you run one you'll never go back to any of the Gator-Dave Brown-or other soft mounts....They don't compare.
The other just put your motor on a rubber "cushion" the Hyde Mount converts the vibration into rotational motion and is very good at it.
They cost a little bit more but the savings will be in fixing your servos 2-3 times more often. I can get up around 200-300 flights on a set of servos before the Pots get worn and need service....On the hard mounted engines of the past I could only get 100 flights if I was lucky.
Go with the Hyde!
Troy Newman
