RCU Forums - View Single Post - Mosqitobite TriPacer Build started.
Old 02-12-2005 | 04:28 PM
  #187
wascamp
Default RE: Mosqitobite TriPacer going on the workbench.
Hey Ken, while you are here I have a question for you. I am setting up my wing servos and came across a slight interference between the aileron and flap pushrods at the center section where they cross. Did you do anything different on your plane than is shown in the manual? I think I will shim the flap sevo up off the servo plate so the rods don't touch. Two layers of ply glued to the underside of the plate will be enoughto lift the servo arm and eliminate the interference. What do you think?
