RE: Mosqitobite TriPacer going on the workbench.
Ken, are you still using just two servis to operate the flaps and ailerons, or does the new setup use one servo per control surface. Are the surfaces directly driven or do you still use the bellcranks. I see the bellcrank mounting plate in the photos but do you still need them?
Roger
