RCU Forums - View Single Post - New Tempest
Thread: New Tempest
Old 02-13-2005 | 03:22 PM
ini
Default RE: New Tempest
Rodney, I have a similar remote glow setup as you have. You can make it work.
Aluminum is a good conductor, you only need to scratch the surface a little.
I tightened the plug once without a copper washer, then scratched surface under one bolt in cylinder/crank joint and under one engine fastening bolt.
After that it worked
ini
