RE: Prop hole diameter question. Help
strange... I've had to ream every prop for my saito's... are you sure this prop has not been reamed? what prop are you trying to use? If you can find a brass or similar tube with a 7MM ID then you can ream the prop to fit the OD thus making a shim/spacer... too me it's not worth the trouble making a shim out of brass tube to remedy the problem... I'd buy another prop.
John
