ORIGINAL: Razguel
BTW: I did not find the walkthrough posted at AMA helpful.
Why did they not have the diagrams for the sequence for 2005 like in 2004?
Are these available somewhere?
What is with the 180 procedure turn? DO i just make a level smooth turn about ?
The items you are referring to are on the IMAC site, not the AMA site.
The walkthrough is designed to give examples of how to place the sequence figures and not how to actually fly them.
As far as diagrams go, I assume you are referring to the Aresti diagrams. They are also on the IMAC site directly above where the walkthroughs are found.
The turn is NOT a procedure turn. It is a 180 degree aerobatic turn. You must establish a bank angle greater than 60 degrees and up to 90 degrees, then complete 180 degrees of turn without varying the bank angle, rate of turn, or altitude. You can find the actual downgrades in the flying and judging guide. Also available at the IMAC site or here:
http://www.scaleaerobatics.org/judge.html
Click on the links for the flying and judging guide.
