RE: Problem with placing the pipe
No you can get it to fit the way it is,,you will need to bend and re-adjust the pipe suport wire a little,,,also if needed you can flare open the header a little to alter the angle of the pipe so it fits square with the header,,I had to do that a little too
look here,,,same pipe
