RCU Forums - View Single Post - Delta CG?
Thread: Delta CG?
Old 02-15-2005 | 08:29 PM
czech89
Default Delta CG?
I am designing a pure delta wing turbine jet from scratch. Is there a rule of thumb for determining the CG on a delta wing, or can I use the geometric method used for a swept wing? Each wing panel has a 27" chord at the root, a 5" chord at the tip and a 16" span for 54 degrees of sweep. I need to know the proper CG location so I can lay out the gear and other equipment. Any help would be appreciated. Terry
