Brisson 3.2 fuel mixture problem...
Engine will idle and run full throttle fine, but the transition from idle to full is the problem. When rapidly increasing throttle from idle to full, the engine wants to die. I've tried opening and closing the low end niddle by 1/16 turn with no success. I started st the factory reccomendations for the needle setting both times. If the throtle is increased slower it does fine.
What do I need to try next?
