RCU Forums - View Single Post - G2 and getting custom planes on it??
Old 02-16-2005 | 05:07 PM
iflynething
Default RE: G2 and getting custom planes on it??
ORIGINAL: Max1
iflynething thank you for all your help. max[8D]
You are most certainly welcome there. Did everything work out alright. Were you able to find where I was saying to go to.
I know that that worked for me sometimes. I used Nero burning software and then when you had to select the file you wanted to burn then I just went under the file at the top of the program and then looked for it there. But that is the alternate way to find stuff about Real Flight...
BTW, if you didn't notice, like I said there is alot of other stuff there also, like the trim schemes, and the airplanes you have loaded and other miscelaneous stuff like that.
If you have any other questions, then I'll do my best to help out you
~Michael~
