RE: specification for CG placement for the Home Run 46 model (Blackhorse)?
I have the same airplane. The manual states that the balance should be 100 - 125 mm back from the leading edge. There is a diagram that shows the location of the C.G. The diagram has the distance measured back from the leading edge where it meets the fuselage - not at the wing tip.
I hope this helps.
