specification for CG placement for the Home Run 46 model (Blackhorse)?
Hello All
Can anyone advise me on the vendor specification for CG placement for the Home Run 46 model (Blackhorse)?
Thanks in advance
Amram
http://www.f3a-israel.com
Thanks in advance
Amram
My Feedback: (20)
I have the same airplane. The manual states that the balance should be 100 - 125 mm back from the leading edge. There is a diagram that shows the location of the C.G. The diagram has the distance measured back from the leading edge where it meets the fuselage - not at the wing tip.
I hope this helps.
I hope this helps.
