RCU Forums - View Single Post - pull start problem on hyper 7.
Old 02-18-2005 | 02:09 AM
vti-chris's Avatar
vti-chris
Default RE: pull start problem on hyper 7.
I've seen an article about pull starters and it seams to me that if you take it apart and remove the socket with the wire and then put it back is like having a plate that everybody uses for non pull start engines.Is there any other differences?Isn't it just a cover to cover that engine nut?
