http://www2.towerhobbies.com/cgi-bin...&I=LXSG87&P=ML
You can use a yank eliminator in lieu of the pull start mechanism. The starter shaft diameter for your os .10 is 6mm so the one in the link should work. You just need to make sure the rear tire won't be in the way.
