Prop/Engine combos for Knife
I used the MVVS .40 with the mini tunned pipe on my SuDoKhoi... Ran great!! I had to pull it off when the internals of the mini tunned pipe let go... I'm going to mount it on a redesigned wasp soon.
Latch is right about the nitro.... Don't go over 5%.... These guys are very high compression.... If you can't get 5%... put a head shim in to reduce the compression.
