RE: Helimax Rotofly control
Actually, I have found that positioning the paddles with slight equal inclination (leading edges up) helps with stability and hovering. Don't know if this results in faster motor wear, however, so try at your own risk. Anyone else try this? Also, I think its very important to make sure the main blades are quite tight (re-tighten after crashes).
