RE: BME CAP Maniac
I did keep hitting the throttle to see if there was any.. I was still getting the feel of the plane.. I defanantly noticed a right thrust issue on vertical lines and hovering which i will fix with some washers. i could have swarn there was a tad of up or down thrust but cant remember wich .. i was concentrating on so many things at the time. I like to address 1 thing at a time so i dont get things way off. I will try it again after right thrust change.. also im going to switch to a 15X4W.. the O.S. 91 does great with that prop. that will probably make a difference too. I have also got to find a happy medeum on aileron high rates. I like mega deflection but it is WAY touchy on high rates the way i had it on last flight.. also need to bump my expo on aileron low rate for smoother landings as ADDICT was talking about.. does yours land a little on the HOT side?
