RE: Securing wing halves?
if it is a foam core wing just get some 1/4 aluminum rod cut to about 8 inches long ,thread one end and glue into the core using probond and let it set up overnight and fit it to the same fuse holes. make the threads about one inch long and leave a small blank spot sticking out so the threads won't work on the fuse sides
