RCU Forums - View Single Post - Securing wing halves?
Old 02-22-2005 | 06:13 PM
Xrod
Default RE: Securing wing halves?
Thanks for the ideas guys!
blabla your method was considered but I could only do that after I have my wing adjusters set up properly..would not allow independent movement of each wing half to adjust for aileron trim.
Aresti yes the bolt might work here, i wonder if you just threaded the ply plate, or is it better to install blind nuts...hard to do now that the root ribs and wing are joined.
Red B I see what you mean about the forces involved...2 rolls in a second is way more than I would ever put this plane through (i think). I hadn't thought of using cable ties...I really like that idea..thanks!
3dd I have no idea what you are talking about. I understand the treaded rod part, but what secures it? Is there a nut inside the fuse???
Steve
