RE: cen mt2 cvs snapping?
alot of people are working on a cvd from another truck that will fit... some are very close but not close enough... I don't have any problems with the fronts other than self inflicted stupidity (driving into a tree with the wheel first... If you are breaking them as much as you are especially at the pin... something is causing it to snap... How tight are the wheel nuts... are you running different tires, how are the bearings? something is causing it......
