Carden Builders, Help !!!
I am working on my Carden 35% Extra 330. Its mcoming along well, I have a couple questions for the Carden Builders here. I am getting ready to glue in the Mounting plywood pieces to the fiberglass cowl, I have them alligned and tacked in with CA, What is the best way to glue them in Epoxy& glass, or Goop? I have seen it done both ways, which method do you guys use. Also Should I extend the length of the ailerons (longer than stock) I have not sheeted the wings yet. Last question what length servo arms should I use on the ailerons, and elevators, I have JR 8411 servos 2 per aileron, 1 each for the elevators. Thanks for the Help, Jack.
