RE: Connecting a Fut 8UAF to a ReaL Flight G2 interlink controller..
At the top of the screen when you have G2 running you need to press on options, then press controller calibration and you will see controller type click on the arrow and you will see two controller types you need to click on the interface one and should work fine, i am also using the 8uaf so it should with no problem.Hope this helps.
