RE: DA50 on CAPX
Hey JohnVH,
You are the only one so far i've seen who has used the DA50. Its difficult to get pictures or any type of template for this setup. DA did'nt have the awnsers either to how to mount it. I understand you removed about 1 inch of the engine box. I think i will try decreasing the stand-off lentgh from the 2.5" to 1.25". That method requires putting a hole through the center of the firewall to accomodate the carb. Do you by chance have any pictures of your set-up for references? Also do you have any other tips i may need to know about this set-up in general? Thanks -a-bunch for the reply and assist.
